-45%
WHIRLPOOL OWFC3C26X – Lave-vaisselle pose libre 14 couverts – ...
339 € 622 €
besoin d'aide pour choisir des pieces poue face monte carlo
besoin d'aide pour choisir des pieces poue face monte carlo Empty besoin d'aide pour choisir des pieces poue face monte carlo
Message  maya.bz Mer 01 Sep 2010, 13:31
hello
j'ai besoin de vous , je sais pas quoi choisir pour ma monte carlo que je transforme en SS
il me manque les partie qui partent du support du radiateur et qui vont se fixer sur le bumper
pouvez vous m'aidez , je sais pas quoi prendre
http://www.dixiemontecarlodepot.com/78-88montecarlo_subSections/s20.htm
DM10548
1983-1988 Monte Carlo SS Top Plate COVER with custom bead roll. This is a cover plate for the top plate that is hard to change out. If your plate is holding the nose up, this cover plate is easier to put on and less expensive than changing the factory top plate. You can have a good looking top plate in 5 minutes with this new cover plate. Just remove the four rear bolts and a few of the plastic rivet fasteners, slide the plate in and refasten back down. Works well with DM10547 as well. - New - aftermarket (Made in the USA)
DM10547
1983-1988 Monte Carlo SS Top Plate filler panels with custom bead roll. A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
DM10546
1983-1988 Monte Carlo SS Top Plate filler panels. A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
DM10646
1983-1988 Monte Carlo SS Top Plate COVER. This is a cover plate for the top plate that is hard to change out. If your plate is holding the nose up, this cover plate is easier to put on and less expensive than changing the factory top plate. You can have a good looking top plate in 5 minutes with this new cover plate. Just remove the four rear bolts and a few of the plastic rivet fasteners, slide the plate in and refasten back down. Works well with DM10546 as well. - New - aftermarket (Made in the USA)
DM10846
1983-1988 Monte Carlo SS Top Plate. Items are made of thick mild steel and powdercoated satin black. Get rid of that pitted rusty plate and clean up the appearance under the hood. A must for every Monte Carlo SS. Part is of heavier gauge metal than original. (Made in the USA)
DM10746
1983-1988 Monte Carlo SS Top Plate filler panels and center plate combo (DM10546 and DM10846). A great way to dress up your Monte Carlo SS and hide all of the ugly headlight and park light wiring and bumper and absorbers. Also includes a new top plate. These items are made of mild steel and painted satin black. Cleans up the appearance under the hood. A must for every Monte Carlo SS. (Made in the USA)
j'ai l'impression que les modeles sont differents
voici une photo de la mienne
besoin d'aide pour choisir des pieces poue face monte carlo Photo_53
encore quelque mois de restauration, et elle sera comme ça
besoin d'aide pour choisir des pieces poue face monte carlo 0312_010
maya.bz
maya.bz
Ville/Région : FRANCE
Masculin Nombre de messages : 451
Voiture(s) : Monte Carlo SS 85
besoin d'aide pour choisir des pieces poue face monte carlo Empty Re: besoin d'aide pour choisir des pieces poue face monte carlo
Message  claude1 Mer 01 Sep 2010, 14:23
il te manque le cover du milieu qui sert de retenue et de finition pour le pare choc et les autres sonts de couvert esthetique seulement pour remplir l'espace entre le pare choc et le haut du support de radiateur dm 10746 semble etre le kit avec les 3 pieces incluse
claude1
claude1
Ville/Région : st jean sur richelieu
Masculin Nombre de messages : 934
Voiture(s) : 1969 camaro ss 396,1969 camaro copo clone,1969 camaro ss,1979 z28,1969 chevelle ss,1978 trans am bandit,1972 mercedes sl450
http://www.ctcollisions.com
Message  maya.bz Mer 01 Sep 2010, 17:13
merci j'ai trouver Mr. Green
maya.bz
maya.bz
